olá deixo aqui as caracteristicas da minha mala solar da voltaic systems
a minha já tem 1 ano e meio, sempre a produzir energia. atravessou angola a dar energia a gps, ao iphone e a máquina digital reflex.
braços
voltaicsystems:
• 4 watts of solar power for fast charging
• solar panels come in 4 color options and protect fragile items inside
• included battery pack which stores power until you need it
• 11 adaptors for easy connection to handheld electronics
• fully padded laptop sleeve for up to a 17" laptop (16.5" x 11" x 3" or
42cm x 28cm x 7cm)
• wire channels throughout the bag for headphones, bladder tubes etc.
• adjustable phone / mp3 pouch on the shoulder
• removable waist strap
• high density padding in the shoulder straps and back
• mesh backing material for better air flow
• shell uses fabric made from recycled pet (soda bottles), which is
tough, water resistant and lightweight
specifications
fabric: 600d shell made from recycled pet (soda bottles), uv
resistant pu, 1680d nylon base, and sandwich mesh back,
inside pockets use pet mesh
• 4 watts of solar power: from three tough, lightweight, waterproof
solar panels
• 4-6 hours of direct sunlight produce enough charge to fully charge a
typical cell phone. 1 hour of sunlight = 3 hours of ipod play time
• battery included: 4,400mah at 3.6 volts li-ion battery pack with 3
voltage settings to store solar power
• when not in the sun, the battery can be charged using the ac travel
charger or dc car charger making it just as useful on the grid as off
• 11 standard adaptors for easy connections to common cell phones
and universal plugs
• includes a car charger socket and usb adaptor so you can always
use a standard charger for your device
• note: it is designed to charge small laptops at 10v. it will however charge
cell phones, sat phones, pdas, gpss, ipods, cameras and most other
electronics
the voltaic solar bags are mobile solar power generators designed to
charge virtually all handheld electronics.
Caracteristicas da minha mala solar - VOLTAIC
biofuturehouse
Autor do tópico - Mensagens: 22
- AQUI ESTAVA AO SOL NUMA PRAIA JUNTO Á BARRA DO KUANZA EM ANGOLA!!!! LINDA NÃO?
- voltaic_bag1.jpg (123.2 KiB) Visto 2363 vezes
