specifications:
dimension (l*w*h):2608*1515*1526mm
wheelbase: 1800mm
wheel type (front/rear):155-80r1277t/155-80r1277t
ground clearance: 110mm
net weight: 940kg
power: 72v ac 6.5kw/48v dc 3kw
electric system: 12v dc
charger: 72v 25a
battery: 12v/200ah*6 lead-acid
max speed: 55km/h (can be restricted below 40km/h)
max climbing capability: 13°
min. turning diameter: 4.6m
braking distance: <6 m
running distance: 130km
charging time: ≤10h
speed control: pedal control /automatic
drive type: rear wheel drive
steering system: rack-and-pinion steering gear
parking brake: hand / rear-wheel brake
battery type: lead-acid maintenance battery
weight of battery: 384kg
battery life: recharging for 500 times
specifications:
wheelbase: 1800mm
net weight: 940kg
charger: 72v 25a
controller : 72v
charging time: ≤10h
specifications:
dimension (l*w*h):3020*1515*1520mm
wheelbase: 2560 mm
mi. ground clearance: 110mm
net weight: 790kg
power: 72v dc 4.5 kw
charger: 72v 25a
controller : 72v
max climbing capability: 30°
charging time: ≤10h
track(front/rear): 1255/1300 mm
specifications:
wheelbase: 2560 mm
net weight: 790kg
power: 48v dc 3kw
charger: 48v 25a
controller : 48v
max speed: 55km/h(can be restricted below 40km/h)
charging time: ≤10h
