detailed product description
1) tire: 20 x 2.125
2) motor: 180w x 24v
3) battery: 24v/8ah nickel hydrogen
4) brake: front/grip brake, rear/brand brake
5) controller: 1:1 system
6) gear: 6 gears
7) n.w.: 21kg
max. load: 75kg
9) measurement: 1,600 x 250 x 750mm
conveyance:
qty/conveyance:
qty/20' gp: 93pcs
qty/40' gp: 195pcs
qty/40' hq: 216pcs
[url=
1) tire: 20 x 2.125
6) gear: 6 gears
7) n.w.: 21kg
max. load: 75kg
conveyance:
qty/conveyance:
qty/20' gp: 93pcs
qty/40' gp: 195pcs
qty/40' hq: 216pcs
mais informações aqui!
5 gears
product size: 1880*620*990mm
frame material: aluminum
power indicator on throttle
battery: 1.2v*30pcs / 10ah lithium battery
power of motor: 220w brushless
max speed: 25km/h
range per charge: 50km
charger life: >500 times
charging time: 5-6h
climbing ability: >=6degree
loading capacity: 90kg
tire size: 26" x 1.75
brake: front: "disc" brake
rear: "v" brake
n.w.: 27.5kg
product size: 1640 x 280 x 820mm
fcl quantity: 66pcs/20'gp, 142pcs/40'gp, 171pcs/40'hc
mais iformações aqui!
liberty mountain bikes
available in lead-acid or ni-mh
coming soon: lifepo4 battery option
frame: hi tensil steel
motor: 250 watt brushless
charger: 110 volt (220/50 optional) smart
front forks: heavy duty dual suspension
mudguards: staight plastic style
handlebars: alloy
controller: 36v/10ah brushless
battery: 36v/8ah
wheels: 26 x 1.95 mtb double wall
rims: 26" alloy
gears: shimano 6 speed
seat post: steel
brakes: front and rear disc brakes
normal load: 250 lbs/ max 275 lbs
weight of bicycle including batteries:
94lb. (lead acid) 82lb (nimh)
charging time: 4-6 hours dependant on use
range: 24-27 miles depending on conditions
maximum speed: 15 mph (faster with pedaling)
assembly: pedals, front tire, fender & light
pricing:
lead acid: $699.00
ni-mh: $869.00
coming soon... lifepo4 option
buy a lead acid now and you can upgrade with a drop-in lifepo4 when it is shipped!
um video!
vou adicionando assim que vou encontrando nos meus favoritos, acho que é mais facil procurar no google do que nos meus favortos...
