General Motors cria infra-estrutura piloto de hidrogénio ...
Seal
Mensagem por Seal »
hawaii is set to get the first hydrogen fueling infrastructure in the united states thanks to a pilot project announced today by general motors and the gas company. the gas company is the local natural gas and propane utility on the island state. hawaii makes an ideal location for testing new transportation technologies as a result of its isolation, and the relatively small size of the islands means that you can never get all that far from the fueling network.
the gas company (tgc) has been producing both synthetic natural gas (sng) and hydrogen for several years. the sng that it distributes to customers through its island pipeline network is currently blended with five percent hydrogen, a percentage that could be increased as needed.
the new pilot project will set up a network of 20-25 hydrogen filling stations on oahu that will tap directly into the pipeline network. such a network can provide fuel access to to most drivers within a 10 minute drive. pure hydrogen can be separated from the flow through a pressure swing absorption system and then used to fill fuel cell vehicles. continue reading after the jump.
[source: general motors]
with its tropical and remote location, hawaii has good reason to want to use renewable energy sources since all fossil fuels have to be imported at considerable cost. while sun and wind are both plentiful in hawaii, the fact that they are not constant makes it problematic for grid stability.
the ability to store hydrogen gives it an advantage, especially if it is produced from renewable sources. hawaii has a goal of achieving 70 percent clean energy within a generation.
havaí é definida para obter o hidrogênio primeira infra-estrutura de abastecimento dos estados unidos graças a um projeto-piloto anunciado hoje pela general motors e da companhia de gás. a companhia de gás é o local de gás natural e propano utilitário no estado de console. havaí torna um local ideal para testar novas tecnologias de transporte, como resultado de seu isolamento eo tamanho relativamente pequeno das ilhas significa que você pode nunca chegar muito longe da rede de abastecimento.
a companhia de gás (tgc), vem produzindo o gás natural sintético (gns) e de hidrogênio durante vários anos. o sng que distribui para os clientes através da sua rede de gasodutos ilha está misturado com hidrogênio cinco por cento, uma percentagem que poderá ser aumentada conforme a necessidade.
o [novo projecto-piloto b] vai criar uma rede de 20-25 hidrogénio estações em oahu [/ b] que vai bater diretamente na rede de gasodutos. esta rede pode proporcionar o acesso de combustível para a maioria dos drivers dentro de uma movimentação de 10 minutos. [/ b hidrogênio puro] pode ser separada do fluxo através de um sistema de absorção do balanço da pressão e, em seguida, utilizado para preencher veículos da célula combustível. continue a ler depois do salto.
[fonte: general motors]
com a sua localização tropical e remota, hawaii tem bons motivos para querer usar fontes de energia renováveis, já que todos os combustíveis fósseis, têm de ser importados a um custo considerável. enquanto o sol eo vento são abundantes no havaí, o fato de que eles não são constantes torna problemático para a estabilidade da rede.
a capacidade de armazenamento de hidrogénio dá-lhe uma vantagem, especialmente se for produzido a partir de fontes renováveis. havaí tem uma meta de alcançar 70 por cento de energia limpa dentro de uma geração. [/ b]
em: http://green.autoblog.com/2010/05/11/ge ... re-in-haw/
