Mini El City!
Enviado: terça set 23, 2008 11:05 am
pois é quando falamos em veículos de 3 rodas eléctricos desconhecemos que começou a ter sucesso com este menino!
vou colocar toda a informação que encontrei na wiki, já que o site oficial da empresa já não existe pois como tantas outras faliu... conto com a vossa parte de se não entendem bem o inglês está aqui um bom tradutor!
the cityel is a 3-wheel light-weight electric car currently made in germany by citycom ag.
the cityel was originally developed as the mini-el by danish company el trans as in randers and was first brought onto the market by them in 1987. after el trans as had to give up production in 1988 and two subsequent manufacturers (eltrans1 a/s in 1991 and eltrans89 a/s in 1995), citycom denmark a/s, a german investor, took over and moved the company to aub. the production is now in aub-baldersheim.
the vehicle is for one person, seated centrally. rather than conventional doors, the whole top-half of the vehicle hinges upwards on gas-struts allowing access to the cockpit.
an optional child seat allows the car to carry a child (up to 8 years), sitting behind the front seat on the engine compartment, facing backwards. the driver operates car-like controls (steering wheel, brake and throttle pedals) although the vehicle is classed as an electric motorcycle in some countries.
there have been three body styles since production started. the 'basic' version has a completely solid roof. some versions have plexiglass side-windows. the convertible was a fully open version no-longer made by citycom. in its place the 'targa' version was constructed, with a removable centre soft top but solid rear windows. in america the city el was sold with a different roof, made out of fibreglass. [1] this roof is slightly different from the factory-built city el roof.
1992 mini-el 'basic' side view
1997 city el 'targa' (or 'fun')
technical specifications
the older version had three lead acid batteries with a 40 (series1) to 55 km/h (series2 and up) top speed and a range from 40 to 50 km (series1 up to 70km). the consumption from series2 and up was 7 to 9 kw·h/100 km. however, the new version factfour has four lead acid batteries, a much better electric motor that provides a 63 km/h top speed and 70 to 90 km range. the consumption is 3.5 to 5 kw·h/100 km. the city el is regularly modified by enthusiasts and it is common to see city els powered by alternative batteries, such as the nickel-cadmium battery or lithium-ion battery.
43v 100ah lithium ion upgraded city el
the improved performance and range given to the city el by using such batteries make them a viable town commuting vehicle with enough acceleration to keep up with city traffic.
a city el weighs only 280 kilograms and the front end can be lifted quite easily. when the batteries are removed it is possible for three people to lift a city el clean off the ground. when a city el is retrofitted with 100 ah thunder-sky lithium ion batteries the car becomes approximately 70 kilograms lighter, bringing the weight of the city el well under that of some motorbikes. at this point the driver has to take extreme care driving at 30mph or more in moderate cross-winds to prevent the city el from being blown about.
uns pequenos videos:
uma pequena apresentação!
[youtube]http://www.youtube.com/watch?v=cft3xh0a ... re=related[/youtube]
um passeio no mesmo!
jmal seria assim tão caro uma up grade das baterias de origem para as de a123?
um há venda!
p.s.: qualquer informação extra que tenham por favor não hesitem em colocar ou rectificar algo errado!
obrigado!
Re: Mini El City!
Enviado: terça set 23, 2008 11:50 am
Re: Mini El City!
Enviado: terça set 23, 2008 9:32 pm
por Bluesky
desculpa sergio, mas o bicho é tao feio, pareçe um caixão com rodas. todavia a ideia é boa, mas noutro tipo de chassis... mais futurista
Re: Mini El City!
Enviado: terça set 23, 2008 10:34 pm
bluesky Escreveu:desculpa sergio, mas o bicho é tao feio, pareçe um caixão com rodas. todavia a ideia é boa, mas noutro tipo de chassis... mais futurista
pois o modelo só tem mais de 16 anos!!!!
mais um para dar o ar de feio aos ve's... mas eu até gosto...
Re: Mini El City!
Enviado: terça set 23, 2008 11:17 pm
por jmal
oi serges, vou tentar escolher um pack de baterias de lítio para ele seja a123 ou outras, sabes dizer mais ou menos que capacidade ele tem de origem para fazer os cálculos.
Re: Mini El City!
Enviado: terça set 23, 2008 11:37 pm
jmal Escreveu:oi serges, vou tentar escolher um pack de baterias de lítio para ele seja a123 ou outras, sabes dizer mais ou menos que capacidade ele tem de origem para fazer os cálculos.
isto!? technical specifications
era uma boa aquisição para cá para portugal, pois era considerado um ciclomotor, substituía os sem cartas...
Re: Mini El City!
Enviado: terça set 23, 2008 11:40 pm
por jmal
serges Escreveu:
isso não ajuda muito, não sei o peso delas nem a capacidade.
Re: Mini El City!
Enviado: quarta set 24, 2008 8:45 am
technical data of his " sonic el:
speed 72 mph(!)
battery 9 optima
battery voltage 108 volt
engine advanced dc a89 6hp/48hp peak
motor control curtis 1221r 72-120v 400a 48kw
battery charger zivan
pouca coisa consigo encontrar sobre este mesmo menino!
standard versions
yuasa 90ah c5 batteries
he standard equipment for city-el are 90ah batteries of yuasa type eb90. this battery type has a relatively low internal resistance, and thus good high current characteristics. the nominal capacity is 90ah c5, i.e. at 5 hours unloading time (5hx1å=90ah/c5). with 1 hour unloading time, which is more realistic, the capacity drops to approx. 50ah (1hx50a=50ah/c1).
nickel cadmium batteries
nickel cadmium batteries have very high amp-hour capacities, very long life span and unfortunately a relatively high price. in the city-el, juice brand stm130 have been fitted, or different batteries of the hoppecke brand. the vehicle then has a range of 80km or more. if the battery gets over the guaranteed life span of the manufacturer, it's per kilometer cheaper than lead, unfortunately no one has gotten that far, since one must drive about 160,000 km.
closed numerical controls batteries have been developed (hoppecke fnc recom). numerical controls batteries are ideal for professionals and many drivers, e.g. courier services. although numerical control batteries give excellent service, they are astronomically expensive.
costs: 10 lead battery records á 1000 dm correspond 1 record numerical control for approx. 10,000 dm
mas lá descobri que existem modelos "tuning" em que ficam muito bonitos!
Re: Mini El City!
Enviado: quarta set 24, 2008 1:09 pm
por jmal
ok, então com equipamento standart ele traz 4 baterias de 12v 90ah pesando cada 1 +- 29-30 kg, portanto as 4 baterias pesam entre 116-120 kg, com 4320 wh, fazendo uma autonomia de 70-120 km dependendo do tipo de circuito, velocidade,etc.
sendo assim com as baterias da thundersky iria propor 2 packs um de 60 ah e outro de 90ah
pack 48v 60 ah
15 células de 60 ah
2.5 kg cada = 37.5 kg
este pack fica por +- 2000 euros, e a autonomia seria a mesma que o equipamento standard do veículo, isto porque estas baterias são mais eficientes e muito mais leves.
pack 48v 90 ah
15 células de 90 ah
3 kg cada = 45 kg
este pack fica por +- 2900 euros, e a autonomia seria por volta 110-150 kms
Re: Mini El City!
Enviado: quarta set 24, 2008 4:53 pm
por Bluesky
tunning? mini-hell city! bah.... ...desculpem-me ahahah
Re: Mini El City!
Enviado: quarta set 24, 2008 4:58 pm
por jmal
com baterias a123 só para terem uma ideia, ficava com um pack de 48v 60 ah, ficava +- em 4200 euros, e com um peso +- de 28 kg. a autonomia seria um pouco acima daquela que tem com o equipamento standard, já que são também mais leves e eficientes.
com estas ou com as da thundersky ficava com baterias para fazer perto de 200.000 kms.
Re: Mini El City!
Enviado: quarta set 24, 2008 9:47 pm
por k__x
e a nivel de segurança?
deve ser um perigo, tanto conduzir esse triciclo( a dar as curvas) como se alguem bater... =(
Re: Mini El City!
Enviado: quarta set 24, 2008 11:41 pm
k__x Escreveu:e a nivel de segurança?
vê lá o video que coloquei e depois diz lá isso outra vez! o tipo chegou aos 60km/h e sem stress a curvar! com o peso das baterias para virar aquilo deve ser complicado!
Re: Mini El City!
Enviado: quinta set 25, 2008 9:37 am
por Bluesky
nao admira, as baterias baixam-lhe o centro de gravidade, vejam o tango tambem. a vantagem é que se tivermos um acidente (sermos atropelados por um camião ou autocarro) já ficamos dentro do caixao, é directo desculpem, é mais forte do que eu!!! de longe que gosto mais da arquitectura do silence, este... nao tem nada em comum mesmo, nem aspecto nem as performances.
