Motores Magnéticos, Spintrónica, Campo do Zero Absoluto, E.G
Azorian
Re: Motores Magnéticos, Spintrónica, Campo do Zero Absoluto, E.G
este tema é muito importante sim, deve ser tratado com rigor.
logo mais organização era bom...
pois é, mas eu não chego a todas nem existe uma perfeita organizaçao neste forum, em primeiro lugar estamos no geral, viram algum topico sobre o zero absoluto ou mesmo o hidrogenio? nao. por isso organizem-se voces, é o que há.
novidades na lutec:
http://www.lutec.com.au/
más noticias, a lutec vendeu a sua tecnologia e não vai entrar no mercado como tinha prometido para março deste ano.
boas noticias, revelou o seu método:
novidades na lutec:
lutec australia pty ltd displays prototypes that amplifying electricity by at least five times. this technology could save our planet but it also begs the question; where does the “extra” energy come from?: lutec replies. in 1831 the great english scientist michael faraday discovered that electrical energy can be produced by magnetism when accompanied by … motion. notice that a rotary device infers motion, one of the two elements required. 167 years later in 1998 ludwig (lu) brits and victor (john) christie applied for patent protection over an invention titled “a means of controlling a rotary device”. the invention, the brain child of lu brits, was further developed by the two men from an existing concept design of lu’s and were subsequently granted patent in new zealand, australia, the usa, mexico, israel, turkey, russia, eurasia, south africa, africa, singapore, vietnam, indonesia and many other countries. see http://www.lutec.com.au for more details. the rotor has permanent magnets embedded and stands in oil drum like fashion on a top and bottom bearing allowing it to spin freely through 360 degree rotation. external to the rotor, steel cores are wound with copper wire and placed in a fixed position independent of the rotor. now of course the rotor cannot spin freely any more because the magnets are attracted to the steel core of the coil and so this is acting as a locking brake. the key is in how to cause the magnet to pass the steel core of the coil that is trying to attract then hold the magnet and so prevent the rotor from revolving. as the magnet is attracted to the steel core of the coil it pulls the rotor with it, this is then motion caused by “natural magnetic attraction”. when the magnet is situated in the appropriate position opposite the steel core of the coil a short pulse of electrical energy is caused to be sent through the coil windings. this has the effect of turning the steel core temporarily into a magnet of like polarity to the permanent magnet. this causes repulsion from each other and so the revolution of the rotor continues. absolutely critical to the efficient running of the machines is the accuracy of the timing and duration of the switching of the input pulse. the rotational speed is dictated by the amount of electrical energy of that input pulse. there is a lot of energy stored in the rotor created by the motion, however the motion itself is the result of the magnets being attracted to and then repelled from the steel core of the coils. there are a couple of other very interesting things that occur about this time that we won’t go into here, and the coils in the lea remain at room temperature even with the coils outputting their maximum energy. so we have a rotor that continues to spin, it is now in motion, the. the motion permits induction resulting in the wiring of the coil/s to become exited. the amount of inputted electrical energy expended that magnetises the steel core of the coils, and does a couple of other things not mentioned here, is a far less amount than the electrical energy produced by the same coils. the input is a separate circuit to the output. all the input energy is expended. the resulting electricity production proves once more mr faradays discovery. so where does the extra electrical energy come from? it’s not extra energy, it is actually newly produced! and it comes from the interaction between the magnet’s natural magnetic attraction and natural magnetic repulsion causing the motion and the magnetism in the coils then producing the new electrical energy, just as mr faraday said it would. mr faraday rocked the scientific establishment of the time back in 1831 with evidence that magnetism and motion create electrical energy. brits and christie are doing the same in 2007 by simply applying the principle extremely efficiently. lutec australia pty ltd. 2007.
manel
conteúdo retirado devido a nada ter com o tópico debatido!
by serges
p.yama
- Contacto:
procuro parceria p/ instalar motor magnetº em trotinete ou trike a vela
aguardo v/ ordens
tlm 919355910
[email protected]
aguardo v/ ordens
tlm 919355910
[email protected]
Luciano Kaefer
corajoso em publicar o seu e-mail na net. existem robots que passam o dia a fuçar foruns através de qualquer coisa que tenha um @ no meio. vendes as listas e depois você torra o saco de receber mail de enlargue penis, viagra, ciallis etc...
sagan
como não percebo nada disto, tenho uma pergunta simples:
estes "inventores" de máquinas de "free-energy", nas suas casas, certamente que não estão ligados à rede eléctrica, pois não?
como inventores de máquinas e teorias tão maravilhosas, certamente que também sabem ligar um gerador à sua "máquina maravilhosa" e acabar com a ligação à edp
Azorian
acho que essas pessoas não chegam aconceguir tal...por interesses superiores da grande industria energética actual, a petrolifera, uma industria de cerca de 3 a 4 triliões de dollars por ano, industria cujo fará qualquer coisa que seja necessário para parar qualquer coisa que os possa por em causa.sagan Escreveu:como não percebo nada disto, tenho uma pergunta simples:
sagan
vejamos: o que impediria estes "inventores" de construir a máquina em sua casa e ligá-la a um gerador? a indústria petrolífera? como? então impedem-os de construir a máquina mas não os impedem de divulgá-la nem de vender "tralha" que explica como a fazer?azorian Escreveu:acho que essas pessoas não chegam aconceguir tal...por interesses superiores da grande industria energética actual, a petrolifera, uma industria de cerca de 3 a 4 triliões de dollars por ano, industria cujo fará qualquer coisa que seja necessário para parar qualquer coisa que os possa por em causa.
frase moderada por contrariar o regulamento
sagan Escreveu:vejamos: o que impediria estes "inventores" de construir a máquina em sua casa e ligá-la a um gerador? a indústria petrolífera? como? então impedem-os de construir a máquina mas não os impedem de divulgá-la nem de vender "tralha" que explica como a fazer?azorian Escreveu:acho que essas pessoas não chegam aconceguir tal...por interesses superiores da grande industria energética actual, a petrolifera, uma industria de cerca de 3 a 4 triliões de dollars por ano, industria cujo fará qualquer coisa que seja necessário para parar qualquer coisa que os possa por em causa.
pra quem gosta do carl sagan, acho que estás ser tendencioso, tudo não passam de teorias, algumas até desafiando algumas leis da física e outras não, mas as ideias permanecem até que que alguém possa desenvolve-las melhor. quantas vezes o thomas edison tentou acender uma lâmpada, acho que foram algumas 2000, se ele tivesse desistido alguém muitos anos depois viria a tentar novamente, os projectos não devem parar e meterem-se na gaveta só porque não funcionaram da primeira vez, devem ficar bem à mostra até que nos ocorra uma nova ideia.
sagan
"empresas" como a lutec afirmam que têm protótipos a funcionar e a demonstrar a tecnologia de eficiência superior a 100%.jmal Escreveu:pra quem gosta do carl sagan, acho que estás ser tendencioso, tudo não passam de teorias, algumas até desafiando algumas leis da física e outras não, mas as ideias permanecem até que que alguém possa desenvolve-las melhor. quantas vezes o thomas edison tentou acender uma lâmpada, acho que foram algumas 2000, se ele tivesse desistido alguém muitos anos depois viria a tentar novamente, os projectos não devem parar e meterem-se na gaveta só porque não funcionaram da primeira vez, devem ficar bem à mostra até que nos ocorra uma nova ideia.
ora isto viola as leis mais fundamentais da física, leis essas que foram verificadas por milhares de cientistas em milhares de experiências por esse mundo fora.
se a lutec tem esses protótipos a funcionar, porque não começa a produzir a sua própria electricidade? essa seria a melhor forma de demonstrar a sua tecnologia.
gostaria de saber se existem moderadores neste forum, porque uma coisa é exprimir o nosso cepticismo, outra é ofender as pessoas. cada um tem o direito a opinião dentro do respeito mutuo #
sagan
quem é que eu ofendi?bluesky Escreveu:gostaria de saber se existem moderadores neste forum, porque uma coisa é exprimir o nosso cepticismo, outra é ofender as pessoas. cada um tem o direito a opinião dentro do respeito mutuo #
eis a prova: http://www.phact.org/e/z/lutec.pdffrase moderada
sagan Escreveu:"empresas" como a lutec afirmam que têm protótipos a funcionar e a demonstrar a tecnologia de eficiência superior a 100%.jmal Escreveu:pra quem gosta do carl sagan, acho que estás ser tendencioso, tudo não passam de teorias, algumas até desafiando algumas leis da física e outras não, mas as ideias permanecem até que que alguém possa desenvolve-las melhor. quantas vezes o thomas edison tentou acender uma lâmpada, acho que foram algumas 2000, se ele tivesse desistido alguém muitos anos depois viria a tentar novamente, os projectos não devem parar e meterem-se na gaveta só porque não funcionaram da primeira vez, devem ficar bem à mostra até que nos ocorra uma nova ideia.
claro que não funciona, se funciona-se era o fim do mundo.
Resonant
eu sou crente quanto a energia do campo do zero absoluto.
a razao disto é simples.. se podems acreditar que um painel solar pode gerar energia a partir da luz solar, porque nao uma maquina que gera energia a partir de raios cósmicos ou energia radiante como tesla afirmou existirem.
vou ver se um dia fasso uma pequena experiencia só para tirar algumas duvidas..se funcionar que bom, se nao, azar o meu que perdi o meu tempo..
quem procura o desconhecido nunca perde o seu perde tempo ... ganha-o ... duas vezes #
Luciano Kaefer
pois, nesse forum existem moderadores que procuram estar sempre atentos. abaixo de cada post, existe um ícone que significa denunciar uma mensagem.gostaria de saber se existem moderadores neste forum, porque uma coisa é exprimir o nosso cepticismo, outra é ofender as pessoas. cada um tem o direito a opinião dentro do respeito mutuo
após ser enviada, toda a equipa de moderação é alertada e corre para ver o que está ocorrendo.
como não utilizaste este recurso, só pude verificar o excesso através da vista normal ao forum.
não interessa qual a tecnologia. não interessa se é certa ou errada. somos aqui, todos propagadores de idéias, e não cabe à ninguém, à ninguém, menosprezar quaisquer tipo de alternativa energética.
podem contestar à vontade, mas menosprezar quem tenta colocar a tecnologia, contraria o nosso regulamento.
sagan
a palavra vigarista significa:luciano kaefer Escreveu: não interessa qual a tecnologia. não interessa se é certa ou errada. somos aqui, todos propagadores de idéias, e não cabe à ninguém, à ninguém, menosprezar quaisquer tipo de alternativa energética.
s. 2 gén.,
indivíduo que engana outro mediante o processo do conto do vigário;
burlão;
ora, este caso da lutec encaixa sem dúvidas nenhumas nesta caracterização. é apenas mais um esquema de "free energy" para burlar pessoas inocentes
nem sequer é original, é uma cópia do scam do joe newman... http://en.wikipedia.org/wiki/joseph_newman_(inventor)
sagan Escreveu:a palavra vigarista significa:luciano kaefer Escreveu: não interessa qual a tecnologia. não interessa se é certa ou errada. somos aqui, todos propagadores de idéias, e não cabe à ninguém, à ninguém, menosprezar quaisquer tipo de alternativa energética.
s. 2 gén.,
burlão;
tal como tudo na vida, existem boas e más pessoas, então e o joseph newman também é um burlão ?
sagan
claro que é. a burla dele está muito bem feita pois construiu um motor que trabalha com tensões elevadas e baixas correntes, pelo que pode ser alimentado por pilhas de baixa capacidade, desde que sejam muitas e ligadas em série.jmal Escreveu: tal como tudo na vida, existem boas e más pessoas, então e o joseph newman também é um burlão ?
isto impressiona as pessoas que não têm conhecimentos de engenharia electrotécnica, mas na realidade é perfeitamente normal. trata-se simplesmente de um motor preparado para funcionar a alta tensão.
há uma forma muito simples de testar este tipo de "máquinas": em vez de usar baterias, porque não colocar um gerador à saída da máquina e alimentar a "máquina" a partir da energia produzida pelo gerador?
se a máquina tivesse realmente um rendimento superior à unidade, esta seria uma forma simples e inequívoca de o demonstrar.
estes "inventores" não estão interessados em demonstrar que a sua "máquina" funciona? então porque continuam a usar sempre uma fonte de energia exterior?
eu sei a resposta
